need a little help or info, I have a 2wd  plan to make it 4wd , so is it better to just get a trans ready to bolt up or change the tail section on the one I have. this is a question, just can't get this keyboard to work right.
It's much easier to get a 4wd transmission.  The output shafts are different lengths so you will need to replace the 2wd one with a 4wd one if just swapping over so might as well just get the 4wd and slap it in.
