mjtjnj Posted May 8, 2013 Share Posted May 8, 2013 Just swapped power doors on and I don't have the wiring in my 87 MJ ...I assume there's a harness in cherokees, anyone have one? Also could use the 2 door cherokee power window switch for the drivers side. Thanks Tom Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 11, 2013 Share Posted May 11, 2013 Tom, I used a XJ two-switch panel from the LR door for the drivers side, and a single switch panel from the XJ RR door when I did mine. The cross-body harness connecting the two is only three wires, so 3-conductor power cable works fine. Didn't do the power locks, but they will also require three wires cross-body. I have lots of door panels/switches. Shoot me a PM with your email address and I can send you a wiring diagram if you want to go that way. Link to comment Share on other sites More sharing options...
