Very High Idle
Glad my input led you to the problem :thumbsup: .  The output from the auto TPS and manual TPS are the same and it will bolt right up to the throttle body.  I had to remove the air intake tube (rubber piece from airbox) to install & properly set the TPS (didn't need to do this with the manual).  I'd also cap the TCU output plug (square 4 wire) so it's waterproof. But, as you mentioned, the auto TPS is a he&& of a lot cheaper...
I've actually got that square plug on the harness, could it just be plugged in even with a manual tranny? Figure I could get 2 birds with one stone and water proof both connectors.
>Use a good quality "auto" TPS.
Have any brands you'd recommend?
Napa or any parts store's "Premium " brand. Well, maybe except Vatozone.
