Sway Bar Relocation Brackets
Here's useful little mod I discovered by accident. I swapped out the crappy factory shocks on my JK with OMEs, and since the OME shocks were thicker, a set of Synergy rear sway bar relocation brackets was recommended by OME. They move the sway bar down 1" and back 1-7/16" for added clearance. So I ordered them here:
https://www.amazon.com/Synergy-Jeep-Relocation-Bracket-8086-02/dp/B00QXCB2OW
https://www.quadratec.com/products/16315_6517.htm
Here's a pic of them and how they mount on the JK rear:
I found out I really didn't need them because my JK isn't lifted (yet), so I thought they might be useful for doing the same thing to my MJ front sway bar to add more clearance between the end links and the coil springs. They fit perfectly and more than doubled the clearance by moving the sway bar down 1" and forward 1-7/16". It also brought back the original bar end geometry when using the factory links, 10-20 degrees above horizontal. The bracket hole spacing, size, thread, and location is perfect for mounting to the MJ frame and sway bar bushing keepers. Pure PnP. So these brackets are an alternative to installing  longer end links with lifts up to at least 3", while also maintaining correct sway bar geometry with the stock links.
