Blue88Comanche Posted April 29, 2013 Share Posted April 29, 2013 Want to Buy the Transmission side linkage mount for a 4wd AX-15 Link to comment Share on other sites More sharing options...
64 Cheyenne Posted May 11, 2013 Share Posted May 11, 2013 don't forget that if this is for a conversion YOU WILL need the part that is on the body side of the transmission tunnel as well. Link to comment Share on other sites More sharing options...
Blue88Comanche Posted May 12, 2013 Author Share Posted May 12, 2013 Unless its different from the BA-10 4x4 I should be good, just need the transmission side if things Link to comment Share on other sites More sharing options...
64 Cheyenne Posted May 12, 2013 Share Posted May 12, 2013 Is different Link to comment Share on other sites More sharing options...
Blue88Comanche Posted May 12, 2013 Author Share Posted May 12, 2013 So the z linkage and the bracket for it in the body also meet to be swapped as well? Link to comment Share on other sites More sharing options...
64 Cheyenne Posted May 12, 2013 Share Posted May 12, 2013 Z linkage is fineOn the body side bracket the hole is in a different location from the one that uses the BA-10 For the AX15, the hole is all the way to the rear of the bracket. BA10, the hole is in the middle. http://comancheclub.com/topic/20403-transfer-case-linkage-components/?hl=trunion&do=findComment&comment=213758 Link to comment Share on other sites More sharing options...
Blue88Comanche Posted May 13, 2013 Author Share Posted May 13, 2013 Z linkage is fine On the body side bracket the hole is in a different location from the one that uses the BA-10 For the AX15, the hole is all the way to the rear of the bracket. BA10, the hole is in the middle. http://comancheclub.com/topic/20403-transfer-case-linkage-components/?hl=trunion&do=findComment&comment=213758 thanks for the info that will save a future headache :cheers: Link to comment Share on other sites More sharing options...
64 Cheyenne Posted May 13, 2013 Share Posted May 13, 2013 If you get conversion parts from the JY just get EVERYTHING for the linkage. and your welcome. Link to comment Share on other sites More sharing options...
