steve88mj Posted April 12, 2013 Posted April 12, 2013 What I have is a rear axle I had put together for the intent of using it in my 88 project that would be able to take some abuse. Everything in the axle is new there are only maybe ten miles that where put on it because i tow dollied my MJ to my new garage. Have two other MJ's and would like to have some $$ to give them some love. It is a stock MJ Dana 35 housing with disc backing plates and the factory perches still on it although I do have long anti-wrap taller spring perches to go along with it. Cleaned and painted with chassis saver. As for the internals I had the G2 chromoley 30 spline axles put in it, all new bearings throughout, Detroit 30 spline carrier/locker, 4 :10 gears. I do have a Dana 30 front axle out of a 4 cylinder, 5 speed XJ with factory 4 :10's. It is a disconnect axle and I was in the middle of trussing, bracing, and rebuilding the drivers coil bucket with heavier steel may let them go as a set. Make me a reasonable offer
Archived
