steve88mj
Everything posted by steve88mj
  1. I have one with nothing wrong with it out of a 4.0 automatic RWD
  2. I have everything you need its in my project MJ I daily drove until I stripped it down last summer to redo it. I pulled the engine I want to go to a high out put so I don't need all the wiring etc. It was a 4.0 with an AW4
  3. It had a renix sending unit but the fuel pump part was pieced together from a 94 HO one. Whomever did it it looks like they took the gas gauge float assembly and cut it off and tac welded the other on there was some things done with the wiring too but I have no idea what I'm looking at never dealt with this issue until now and I have had 5 MJs 2 where HO I'm glad all the other sending units held up I was lucky because I happened to save a sending unit and had no idea you can't buy new ones. I will try to get a pic of the old sending unit so you can see what the guy did the gas gauge and everything worked fine?
  4. Just like title says I need a good sender for a 91-92 4.0 MJ
  5. I have a good renix fuel pump from an MJ will that work? Someone told me an XJ would work but the gas gauge will work backwards?
  6. Someone already put a band aid on it once I was going to try to patch the leak until I saw that rock auto doesn't have one listed nor any part stores.
  7. I need the entire assembly not just the pump itself so yes I need the sending unit
  8. Auto parts stores said ho mj fuel pumps are discontinued?
  9. I need to know what fuel pump I need to buy asap the truck has the complete HO swap I got the truck on trade and the fuel pump on it is leaking very bad out of the elbows that the rubber line clamps to the assembly outside of the tank because of rust. Can I just buy a HO Cherokee one or? The old one looks like it was cut and tac welded together from two different pumps. My gas gauge doesn't work right either? The metal lines that come out of the HO pump on the outside has one large one and one smaller one. Mine just has two of the same size that come out and straight up 90 degrees. The HO just sticks straight out. Anybody know what I need to do?
  10. I have a good ax-5 in pa
  11. How much?
  12. I need a set of drive shafts for a long bed Comanche with the 4 cylinder, 5 speed, & 4x4 Thanks
  13. I never actually put kicker shocks on the truck yet I'm going to see if I actually need them first. Keep watching though I will have pics of everything once I figure out how to post pics on here I'll try to keep it updated!
  14. Why do you say that? The stock main with the added half spring that comes of the frame makes 3/4's of an elliptic circle. That is why it is called a 3/4 elliptic setup man do a yahoo images search of 3/4 elliptic lot of people do it to yj's and I have an 88 Yj with this setup at home. I'm not going to argue on this forum about it.
  15. Having trouble loading pics hopefully I get it figured out when I get some time. Any thoughts on my rear suspension setup?
  16. I figured now that I am a member of the site I could start my build thread! I already have one started on cherokee forum so here is the link for the first part of the build: http://www.cherokeeforum.com/f46/88-mj- ... tc-104510/ I will update my build from here so keep watching!
