snakedoc67 Posted April 10, 2013 Share Posted April 10, 2013 Have the interior parts out of my 88 parts truck for sale. Prices are best offer and shipping is on your dime. Can see pictures at . Dash panel lower dash panel/with ashtray Power option doors (from Cherokee, installed by PO) overhead panel from Cherokee L/H over door moulding L/H and R/H lower mouldings L/H and R/H Cowl panels L/H and R/H Quarter trim panels Upper rear panel under rear window Wiper motor cowl panel Bench seat frames/Sunvisors- both of these are tore up or moldy enough that only the frames would be any good. Also have most of the front end parts available from this truck, front fenders, 2wd front axle, hood, rear window (non sliding), driveshaft. The truck was a 2wd, 2.5, AX-4,shortbed. Link to comment Share on other sites More sharing options...
SBpunk Posted April 10, 2013 Share Posted April 10, 2013 Do you have the visor clips still? Link to comment Share on other sites More sharing options...
snakedoc67 Posted April 12, 2013 Author Share Posted April 12, 2013 89MJ98XJ, I will have to go thru some small parts bins to check, can let you know by tomorrow for sure. Link to comment Share on other sites More sharing options...
manchemanche Posted April 14, 2013 Share Posted April 14, 2013 i need the lower dash peice with ashtray is it in good shape with no cracks Link to comment Share on other sites More sharing options...
snakedoc67 Posted April 15, 2013 Author Share Posted April 15, 2013 Manchemanche: nope, there is a large crack in it, should be visible in the pictures on photobucket. Might be fixable with some JB Weld. Link to comment Share on other sites More sharing options...
snakedoc67 Posted September 23, 2013 Author Share Posted September 23, 2013 Bump. Still looking to sell all of this. Also can add an ECU/computer from the same truck. Link to comment Share on other sites More sharing options...
87MJproject Posted June 12, 2014 Share Posted June 12, 2014 do you still have the tan b pillers the plastics that the seat belts are on with the dome lights? Link to comment Share on other sites More sharing options...
snakedoc67 Posted June 12, 2014 Author Share Posted June 12, 2014 They are still available. There are some small cracks in the edges but nothing that would make them unusable. Pictures can be seen at the link above. Link to comment Share on other sites More sharing options...
MJJiM89 Posted September 6, 2014 Share Posted September 6, 2014 I know it's been a while, but are these still available? Link to comment Share on other sites More sharing options...
snakedoc67 Posted September 12, 2014 Author Share Posted September 12, 2014 MJJim89, I still have them. Does $40 plus shipping sound good? Link to comment Share on other sites More sharing options...
MJJiM89 Posted September 13, 2014 Share Posted September 13, 2014 Sounds great! I sent you a PM about it. Thanks. Link to comment Share on other sites More sharing options...
MJJiM89 Posted September 30, 2014 Share Posted September 30, 2014 Thanks for the square deal and the smooth transaction. Link to comment Share on other sites More sharing options...
snakedoc67 Posted October 7, 2014 Author Share Posted October 7, 2014 no problem, glad they work for you Link to comment Share on other sites More sharing options...
jeepevy Posted October 30, 2014 Share Posted October 30, 2014 Looking for black 2 spoke steering wheel including button and all hardware. Horn button is triangular in shape also looking for turn signal switch need to fit 88 mj 2.5 tbi swb if you don't have steering wheel 2 spoke I'll take 3 spoke with circular horn button Link to comment Share on other sites More sharing options...
Archived
