87MancheMan Posted February 26, 2013 Share Posted February 26, 2013 Hey all just replaced my TREs and the TRE at the pitman arm and didn't take measurements of the draglink like i did the tie rod :fs1: , can anyone give me an overall measurement of their stock draglink as well as a measurement from the adjusting collar to the fixed TRE and from the adjusting collar to the TRE at the pitman arm, this is just so i can get it as close as possible before i get it aligned during my build process. Thanks for the help. :cheers: Link to comment Share on other sites More sharing options...
87MancheMan Posted February 27, 2013 Author Share Posted February 27, 2013 Nobody? Link to comment Share on other sites More sharing options...
HOrnbrod Posted February 27, 2013 Share Posted February 27, 2013 Do the toe adjustment with the tie rod sleeve using the tape measure procedure detailed at this link: http://gojeep.willyshotrod.com/HowtoAlignment.htm The drag link adj. sleeve's purpose is to center the steering wheel after you correct the toe. Also shown in the link. Link to comment Share on other sites More sharing options...
87manche1 Posted February 27, 2013 Share Posted February 27, 2013 Turn wheels straight, i bet steering wheel is off, adjust till your wheels are straight and steering wheel is straight. Id measure mine but i need to adjust mine yet and lift is going in soon so mine will be different than urs. Link to comment Share on other sites More sharing options...
