dinghyboy Posted February 22, 2013 Posted February 22, 2013 I have read a number of the posts on the CCv system but the problem I'm having is that the part numbers listed seem to be for 1987-1990 jeeps. I've been to the websites for NAPA, Advance and Rock Auto and did not see any listings for the hoses and connectors for a 1992 4.0L. Does anyone know the part numbers or even a parts store that has them or are they dealer only. I appreciate any advice. My hoses have all deteriorated and the rear valve cover connector was blocked solid. There is a solid 1/8 to 1/4 inch of sludge over all the valves, springs, rockers and any surface under the valve cover. I don't think I've ever seen an engine with this bad a layer of build up. Thanks for the help. Gavin 1994 Comanche base 4/0L A/T 4WD
JFAComanche6 Posted February 22, 2013 Posted February 22, 2013 Check the junkyard for at least the grommets, and get the vacuum hoses if they're decent. Maybe look for new Cherokee parts online? Good luck with that sludge, sounds scary...
