420manche Posted January 23, 2013 Share Posted January 23, 2013 So I am fairly new to the mj's and my only spot of rot is the drivers foot area. So I pulled out my carpet after looking around on the forum and sure enough you can see how it leaked over the years down around the fuse panel. So what's my next step..... And how do I clean the residual gunk that has consumed the fuse block. I would like to get this all fixed before I reach the floor pan. Any help is appreciated Link to comment Share on other sites More sharing options...
Blue88Comanche Posted January 23, 2013 Share Posted January 23, 2013 Replace the master clutch cyl. When you replace it use dot 5 brake fluid, it will not eat up the fuses if it leaks. Make sure you get all the dot 3 out of the system. If the fuse box is in good shape replace all the fuses and clean it out with terminal cleaner. If the box is too far gone then replace it. Link to comment Share on other sites More sharing options...
Blue88Comanche Posted January 23, 2013 Share Posted January 23, 2013 To replace the master clutch cyl is easy. Disconnect the clutch line, disconnect the petal, remove the 2 bolts holding the clutch cyl to the fire wall. After it is on bleed the system Link to comment Share on other sites More sharing options...
420manche Posted January 23, 2013 Author Share Posted January 23, 2013 Sweet thanks that's kinda what I was thinking but you guys eat breathe sleep these trucks so I wanted guidance from those who have done. I would like to solve that before fixing the floor pan. Link to comment Share on other sites More sharing options...
420manche Posted January 23, 2013 Author Share Posted January 23, 2013 Also let me throw this out for sone opinions.... My daily driver 97 xj is in kinda sad shape( bad bad rot broke door hinges lots of worn out stuff) how long does a 97-01 interior, drivetrain, door, and front clip swap take if ya just go at it non stop? I will Gladly use up some vaca time to do it Link to comment Share on other sites More sharing options...
Blue88Comanche Posted January 23, 2013 Share Posted January 23, 2013 the front clip, fenders, and doors should not take long, maybe a day or 2 at the most.. The interior i can't say as i have not messed with my interior much. here are a couple 97+ write ups http://comancheclub....97-swap-how-to/ http://comancheclub....rs-mirrors-ect/ Backdraft converted his mj and has everything in his build thread http://comancheclub....001-eliminator/ Link to comment Share on other sites More sharing options...
420manche Posted January 23, 2013 Author Share Posted January 23, 2013 Awesome thanks again for all the help Link to comment Share on other sites More sharing options...
Blue88Comanche Posted January 23, 2013 Share Posted January 23, 2013 :thumbsup: Link to comment Share on other sites More sharing options...
