89JeepMJ Posted December 7, 2012 Posted December 7, 2012 just refresh my memory xj shackles on a mj will lower it, correct? how much? and what yr xj can i use them off of?
87jeepmj Posted December 7, 2012 Posted December 7, 2012 They will lower it yes probably about a half inch to an inch and any year xj will work
Garvin Posted December 9, 2012 Posted December 9, 2012 Be careful with XJ shackles if you plan on flexing out the rear of the Jeep as they have a tendency to invert and can ruin the springs. If you don't flex the Jeep out then you should be fine and 87jeepmj is correct, they will lower between 1/2-1".
89JeepMJ Posted December 10, 2012 Author Posted December 10, 2012 I really looked at the truck today and realized it doesnt need to go down. I did an SOA and though it was to high but its about where its should be. so i just got regular MJ shackles. thanks though for all the input guys.
