jbain Posted November 8, 2012 Share Posted November 8, 2012 I just finished up swapping a 91 Harness and HO into my 88 MJ and I have power everywhere except the rail, the distributor, the fuel pump (hot wired it and it works) and when I cycle the key I get no lights or buzzers. The Engine rolls fine and I know the harness worked in the old Jeep and the Crank Sensor has already been replaced. I Changed the complete engine Harness and Dash from the 91 Donor but I did not change the column because everything plugged in correctly. Any help would be greatly appreciated. Link to comment Share on other sites More sharing options...
64 Cheyenne Posted November 10, 2012 Share Posted November 10, 2012 Grounds - engine to frame, battery, body? Since the elec problems are at the engine, I would double check engine harness connections. Link to comment Share on other sites More sharing options...
