DansGreyMj Posted March 3, 2007 Posted March 3, 2007 currently I'm at 3" using stock upper and lower fixed rancho control arms, if i decide to go 5-6" and use drop brackets could i get away with using the control arms i am currently on drop brackets at 6"s TIA Daniel
CEThomas Posted March 3, 2007 Posted March 3, 2007 Check out this web site: http://www.yuccaman.com/jeep/re_db.html But at 6" you should be at 16" LCA and 15.5 UCA, stock is 15.75" LCA stock and 15" UCA stock. If you stay stock you could have problems. Charles
DansGreyMj Posted March 4, 2007 Author Posted March 4, 2007 acording to that chart if my lowers are 16 than i would only need to replace the uppers
