Here I Go Again
pug
I got motor rebuilt twice within a year what a nightmare. Has being running great since march. Changed oil last weekend same oil same oil filter (not a fram) now have a knocking sound from top of motor. Idels smooth runs great even getting better gas milage don't know why its a 2.5 ax5. any ideas. thanks
If you're not familiar with the various tapping and knocking sounds, go get a stethoscope from any autoparts store. Listen close and try to isolate where the noise is coming from.
If its on the top like you think and is more of a tapping sound, it could be as simple as taking the valve cover off and torquing the rocker arms to spec. Worse case, could be a bent valve or broken pushrod...hard to diagnose without hearing it. But a broken valve or pushrod will effect the idle. I'm thinking its just a rocker arm.
