4.0L Motor Build Need Some Help.
hey guess I'm trying to work on my motor its a 4.0L. i had the block boared out to fit 0.20 size pistons. The crankshaft is still stock and connecting rods are too.i have a upgraded camshaft from comp cams. i trying to put the motor back together. so i believe i have half the motor back together. i have the crankshaft, connecting rods, pistons, camshaft, freeze plugs, and i wanna say the timing is done. i have the head done in the shop. I'm looking for advice and step by step (pic by pic if possible) on how to put the motor back together. any help would be helpful and apprciated
If you didn't keep the bearings and the connecting rods in order and reassemble exactly as it was before you're risking spinning/burning a bearing. Might be best just to take it to a reputable machine shop and have them reassemble it for you. Should cost around 300 bones for a complete reassembly, plus any other machine work. Connecting rod, bearing and crank endplay is a precise measurement. Best not to wing it. If you removed the crank, you might as well put in new bearings, but the crank journals need to be mic'd, depending on wear, they may need to be re-ground which would require oversized bearings.
