banshee Posted August 13, 2012 Share Posted August 13, 2012 Gentlemen A posed question, if a man was to need the required measurements for the opening on a manche lower control arm bushing, where would a man find said information? Meaning if I was to wish to make new lower control arm mounts and I wished to know the required opening requirements dose any one already have or know this tidbit??? Thanks B… Link to comment Share on other sites More sharing options...
nhrocker Posted August 13, 2012 Share Posted August 13, 2012 I'm guessing you're looking for the stock bushing width, or direct replacement size? That would be roughly 2.625" wide with a 9/16" bolt hole. Link to comment Share on other sites More sharing options...
banshee Posted August 14, 2012 Author Share Posted August 14, 2012 COOL that is the lower bushing size? correct? thanks B... Link to comment Share on other sites More sharing options...
mvusse Posted August 14, 2012 Share Posted August 14, 2012 I'm guessing you're looking for the stock bushing width, or direct replacement size? That would be roughly 2.625" wide with a 9/16" bolt hole. Ummm, maybe close to 9/16, but they are metric. Link to comment Share on other sites More sharing options...
Eagle Posted August 14, 2012 Share Posted August 14, 2012 I remember that the rear springs are 14mm -- if 9/16" is close for the front, then those are probably also 14mm. 9/16 = .5625 14mm = .5512 Link to comment Share on other sites More sharing options...
banshee Posted August 15, 2012 Author Share Posted August 15, 2012 Thanks looking to relocate them slightly lower http://www.rocky-road.com/media/comanch ... _small.jpg only $215 can't build them for that??? B... Link to comment Share on other sites More sharing options...
