cody4359 Posted August 3, 2012 Share Posted August 3, 2012 the driver side of the mj floor needs alot of work, rust going halfway up the tranny tunnel. I'm sure i can make it work, but does anybody know for sure if they are the same exact thing, meaning the bends/reinforcment beads etc lineing up? and also, the crossmember or lower radiator support, did that change over the xj/mj years? the mj has a 97+ radiator in it and i don't like the crossmember, kinda browsing to see if i need a 97+ or what. Link to comment Share on other sites More sharing options...
COFFMAN Posted August 3, 2012 Share Posted August 3, 2012 Hey Cody think you will find the hump is identical The floor pan is different (changes) under under the seats As for front crossmember carn,t say for sure but would think they are the same BTW nice truck dude Link to comment Share on other sites More sharing options...
Eagle Posted August 4, 2012 Share Posted August 4, 2012 A friend of mine cut the driver's floor pan out of an old XJ in my yard and used it to repair his MJ. The tranny tunnel part was fine, but he had to do some customizing in the middle of the floor pan due th the MJ floor braces. Link to comment Share on other sites More sharing options...
