bbe Posted July 19, 2012 Posted July 19, 2012 Last Saturday, I lost the right rear axel on my MJ in Sweetwater. I had it towed to Miller's Automotive and they are having problems locating parts. It is an 88 longbed 4 by with an automatic and the 4 liter engine. Can anyone help in locating a usable rear end? I am running out of vacation time. I am located in Coker Creek which is just south of Tellico Plains. Thanks, Bill
dave92cherokee Posted July 19, 2012 Posted July 19, 2012 What rear end do you have in your MJ the 35 or 44? If it's the 35 you can easily grab the axle from any xj with a 35 rear end to use in it.
ParadiseMJ Posted July 19, 2012 Posted July 19, 2012 What rear end do you have in your MJ the 35 or 44? If it's the 35 you can easily grab the axle from any? xj with a 35 rear end to use in it. Gear ratio, check the gear ratio.
