Hi there!
:dunno:
After one week looking around , i finally found what i need, and so helfull for anybody don't knows, there is MJ broken leaf packs, with Ford Explorer packs.
The specs that i pesonnally go with : MJ = 55'' eye-to-eye, center bolt at 31 - 24, arch at 7'' by 2.5''
The closer i got, is from a Ford Explorer = 6.5'' eye-to-eye, center bolt at 31.5-25,arch at 6'' by 2.5''
I confirm that the specs taken from 4'' lift, and that the Ford Explorer stock lift an MJ 4'' bolt-on. Only have to drill a bigger hole into the leaf bracket and to grind the center bolt's nut to be round, and zip-zap, 2 brad new leaf spring pack... Levelled to the front 4'' lifted :yes:
I'd never said that i want to built a show room condition...
... but Grey/Tan/Black interior will be good for me for a while ! It don't miss any parts, and nones are broken, that is the most important for me a this time :roll:
The first drive at all... half turn around the house... so slowly because drive shaft to short :doh: and... no break lines at all !
It forward, it reverse, it turns, it do not leak anything and don't puff, that is the important at this time for me. Next week-end for breaks and driving shaft... :wavey:
  • 2 months later...
After 2 off-roading deep in the mud... something finally broke... the 4 bolts retaining U-strap at the universal joint rear yoke. Surprise that the casing of the slip y0ke did not broke; Only 4 bolts and lost 2 bearings of the universal joints, ... and a yoke that have 4 bolts broken in!
  • 3 weeks later...
  • 1 month later...
Merci l'ami! Ton noir va etre assez ca coche ....Loll
Some of you will maybe disapointed!!!
My wife wating for a baby, she have 5 months done.** So i had to cut the MJ long box and weld shorter at the front of rear wheels of the box, to buy a Toyota king cab, cut the XtraCab end of cab , cut the end of MJ rear cab, weld the toy XtraCab on it along with align and weld the box, and it became an MJ king cab short box... :) :) :)
Just Joking, but want my copyright dues on that ;) Lollll
**So, I'm in the need of a car :( or a SUV :( or a king cab pick-up truck :) :) . That's why i had to sell Project MJ black that had AMC360 power train GM12 bolts+44 axls, none of mecachanic installed, and i kept ALL lether black Pioneer interior complete and unbroken and sold all the project for 500$, and MJ green always with automatic tranny 8'' lift w. brand new rancho shocks for 2,500$ , all that to buy that king cab pick-up truck. It is a Chevy 1992 2500HD, king cab step side, diesel 6.5L(396 Detroit) manual 5(L123OD) NV4500 transmission, 4x4 FULL EQUIPED, with Rancho 8'' full kit and 35'' BF all terrain. That mean that i have to 3'' lift the body to fit 39.5'' without cutting anything...??? Anyway, that is for personal daily use offering space for baby easy on the back seat and safe for family. Let the winter doing its part, after that will have an MJ red to swap the unmatched interior trim for black pioneer interior! Some pick of that MJ will follow as i work on it! See you soon all of you ;)
