Anybody got body/frame diagrams...?
I've got this for the model 63 (SWB).
Image Not Found
And a couple more out of the same book which detail the body mounts for the bed.
The problem is it is a frame/body repair diagram and everything is measured off the centre of datum points. Which is fun, but not really what I want.
So, anybody have any others? Out of any of the other FSMs?
It's straight enough already. Maybe out 1/2" on the front...
I've decided to part ways with the unibody. Sorta. I wasn't planning to totally reveal my plans until I'd figured them out... But the gist is to build a new frame with new running gear then pop my old cab off the current one and swap it over. That way I can play around with everything on the frame and wheel the current buildup as is until the frame and everything attached to it (minus the cab and a bit of work related to that) is good to go.
Or, it's an idea I'm toying with but may not do because of time constraints.
Anyways, I've been working on the dimensioning of this project for a while here, and a diagram that wasn't ment just for alignment would be nicer...
I think I've got part of the problem figured out now...
JB, I'll get you those diagrams... Your's a SWB or LWB? Looks like they're the same... But, if you could, show me more pictures of how you cut out the cab and attached it to your frame. You ditched the floors and a bunch of the firewall. It's looking like this is the way to go to actually make it sensible...
