Squeegy410 Posted May 5, 2012 Share Posted May 5, 2012 My front shaft needs replacing. Is this a common problem for Pugeot 5 speeds and will it suffice to pull one from the junk yard? Link to comment Share on other sites More sharing options...
Geonovast Posted May 6, 2012 Share Posted May 6, 2012 It's going to easier, and probably cheaper, to upgrade to the AX-15 instead of changing out parts on the pukey. If that's simply not an option though, I would just swap for another pukey. Pulling just the front shaft out of JY trans would seem silly, since the trans itself is probably fine. Link to comment Share on other sites More sharing options...
