randoms wires
as ive gone through the front of my comanche x with a 2.8, ive noticed there are a lot of wires just kind of floating around in there. they all seem factory like a have some stuffed between the washer bottle and the radiator. they have plugs but nothing to plug into. theres some by the passenger side firewall as well. were these intended for the 2.5 and i don't have tbi so do i just have the remnants of a wiring harness. are there certain accessories that are intended to go there but didnt come in my trim level? more info on the jeep 1986 2.8 2bbl 5 speed 4x4. anybody have any ideas? pics will be up later.
On any Jeep, although Renix ere seems to be the worst, you will find many loose wires just hanging. Rather than use a separate wiring harness for different options, they just made up one harness and used it in everything. If you have every factory option on the Jeep there won't be any loose wires. Get a wiring diagram and check the color codes and general location of the wire. That will tell you what it's for.If everything is working, then don't worry about it.
