knever3 Posted April 25, 2012 Share Posted April 25, 2012 "87 Jeep Comanche 4x4 auto 4.0L, cruise from a '90xj swapped in along with the computer and harness complete with fuse box etc. My cruise control isn't working. I replaced the stalk on the column and checked the wiring and can't figure it out. The white wire is plugged into the fuse box for power, the box is connected under the dash, all the connectors are plugged in and the linkage is hooked up. So where do I go from here? I noticed there is a 4 amp fuse inline under the dash and when I turn the ignition on it doesn't have power. I don't know what this fuse if for if it doesn't work with the ignition on? :nuts: Thoughts? Link to comment Share on other sites More sharing options...
JeffN Posted April 25, 2012 Share Posted April 25, 2012 Do you have the switch for the brake pedal in place? It won't work without one. Link to comment Share on other sites More sharing options...
bighause Posted April 25, 2012 Share Posted April 25, 2012 I did the same swap and had two problems, I didn't hook up the "telephone wire" (I think that's what it's called) it's the thin one that runs to the stalk. Its not part of the 2 large connectors that are on the column. I also found out my switch on the stalk has to be wiggled a little sometimes for it to work. Link to comment Share on other sites More sharing options...
knever3 Posted April 25, 2012 Author Share Posted April 25, 2012 Do you have the switch for the brake pedal in place?It won't work without one. Yes I have the brake switch hooked up along with the vacuum lines. I haven't read the scematic and tested each wire yet though. Thanks! Link to comment Share on other sites More sharing options...
