Jk44s in an MJ?
Depending on your axles you may or not have the CV style front yolk.....if you do then you might consider picking up the u-joint style yolk from a junkyard to make things easier for you.
Yep, all UK WJs had the CV front shaft, I have a Tom Woods UJ shaft & yokes that was on my WJ before I went to a double double cardan shaft with the 4.5" lift that I will reuse on the MJ, will need shortening though.
Well if you wanted to pickup a set of moabs you can find them reasonibly here in the US. A local guy had a set of 5 for sale recently for $200. You would spend a good amount of money on shipping I'm sure though......
  • Replies 50
