nitroxsteve Posted April 16, 2012 Share Posted April 16, 2012 Can anyone tell me how much of the output shaft should be sticking out past the mounting flange? I am changing the tail shaft housing on a 2wd trans to 4wd. I measured and calculated but I don't have a 4wd trans to compare it to. Thanks, Link to comment Share on other sites More sharing options...
Geonovast Posted April 17, 2012 Share Posted April 17, 2012 You need to change the output shaft of the trans... you can't just swap the housing. Link to comment Share on other sites More sharing options...
nitroxsteve Posted April 17, 2012 Author Share Posted April 17, 2012 You need to change the output shaft of the trans... you can't just swap the housing. The shaft is splined all the way up and can be cut to the proper length. Link to comment Share on other sites More sharing options...
Geonovast Posted April 17, 2012 Share Posted April 17, 2012 And what's the spline count on it? Last I checked the 2wd BA 10/5 was 27, but it's possible I'm wrong. Link to comment Share on other sites More sharing options...
nitroxsteve Posted April 18, 2012 Author Share Posted April 18, 2012 And what's the spline count on it? Last I checked the 2wd BA 10/5 was 27, but it's possible I'm wrong. 21 Link to comment Share on other sites More sharing options...
