cordark615 Posted April 11, 2012 Share Posted April 11, 2012 Will any long arm lifts for a xj fit on the front of my 90 mj,also if i do a soa in rear how tall of springs will i need in front? Thanks Link to comment Share on other sites More sharing options...
xjrev10 Posted April 11, 2012 Share Posted April 11, 2012 Will any long arm lifts for a xj fit on the front of my 90 mj,also if i do a soa in rear how tall of springs will i need in front? Thanks Search around a bit. These questions have been answered in great depth many times here. Short answer is yes with some grinding depending on what kit or brand of suspension and 4.5-6.5 depending on how healthy your springs are. I like keeping things spring under to keep axle wrap at bay... Welcome to the club! Link to comment Share on other sites More sharing options...
SW86 Posted April 12, 2012 Share Posted April 12, 2012 yeah they will work. basicly from the doors forward MJs are almost exactly the same as XJs. i have RK long arms that the site says might not work with 1990 and earlier models, mines a 88. no issues what so ever. and yes depending on wear of the rear leafs its anywhere from 4.5-6.5. i know some people on here had to go a hair more then that with coils/spacers up front to level it off. that was only a hand full of people IIRC. also check out barnes4wd.com for longer perches when you do the swap to help fight that axle wrap. spring under sucks but gets the job done. just expect to beat and bang the leaf plates/shock mounts on everything! plus in mud they really do act like road graders and take up too much ground clearance IMO Link to comment Share on other sites More sharing options...
