90 comanche in New Mexico
danno
Hello
Here is a link to CL with pics.
http://albuquerque.craigslist.org/cto/2942887788.html
Mods:If adding a CL link is verboten please let me know and I will add pics.
1990 Jeep Comanche 4.0 5spd 4x4 longbed 143k.
I bought this a little over a year ago thinking I would like to get into Jeeps but have been missing Toyotas so...
Good
Runs well
AX15 trans with external slave conversion
Year old NAPA clutch, slave, master and line
8 month old NAPA battery and starter
2" budget boost lift
Year old shocks (4)
Grand Cherokee front swaybar links
Year old 31x10.50 Definity Dakota mud terrains (Pep Boys specials) on newer Jeep steelies. 95% tread left.
All fluids replaced a year ago
"Closed" cooling system removed with filler tee in upper hose
Upper and lower NAPA rad hoses, thermostat, and heater hoses new
E-fan relay wired to a switch
Engine grounds refreshed/updated
Interior fuse box cleaned well
Year old NAPA plugs, cap, rotor, and wires
Interior is pretty nice
Full gauges
Aftermarket sliding rear window in great shape. Lock works
Some wiring repaired. Nothing bad just old crusty wires replaced here and there
I am the second owner. NM native truck. No floorboard rust.
Bad
Slight engine knock. 15/40 oil mostly cured it.
When I did the clutch/bellhousing I did not get the flywheel turned so the clutch chatters
Kinda ugly
No headliner
Clutch master was leaking and got some on the fuse box (as usual)
Parking brake pedal ratchet stripped
Has been in an accident at some point so there is bondo work on the bed and door
Driver door hinge welds broke at some point and the previous owner welded them back on badly so the door doesnt quite line up and is hard to close
Dana 30/35 axles with 3.08 gears
Transfer case (231) is a little noisy
Needs to be aligned after the lift
There is probably more good and bad but thats all I can think of right now. Basically I bought a neglected truck from the original owner and threw a bunch of money at it then decided I don't like the vehicle. Its got good and bad points and is a somewhat rare truck to play with or leave as-is and use as a dump-run truck.
Archived
