RENIX MJ Fuel Pumps
The sender in my 88 LWB is bad and I have a lead on a pump assembly from an 89 SWB. From what I understand, the SWB sender should work on my LWB tank because the tank has the same depth and width but a different length. Is this correct?
Also, do any RENIX MJ senders work in any RENIX MJ tank?
