my mj has a new 4.5 RC suspension lift and a new adjustable track bar and I replaced the bearing and races last weak and last night i was driving on the interstate home and hit a small bump and my the front end was shaking from side to side crazy then i jerked the steering wheel and it strengthened up and drove it home but it did it two more time before i got home. I jacked the front end up and moved the tire and the bearing have no play but when I moved it side to side the tie rod and the steer rod where moving and so was the arm on the steering box and the steering wheel in the truck. what could be the problem the tie rod ends or the steering rod ends or is the steering box is shot please help I'm clue less :???: :dunno: :help:
