chad m Posted March 9, 2012 Share Posted March 9, 2012 i just bought a 89 comanche 4.0 auto 2wd shortbed that i am using for dd/work in need of a few things would like to find a few local sources hp dana 30 stock control arms the rod that connects the rear end to the load sensing valve rear sliding glass both doors will consider newer model xj would like black but any color will do matching door lock set ladder rack for short bed parts for closed cooling set up 4.0 oil pan and valve cover located in statesville will travel for a good deal Link to comment Share on other sites More sharing options...
500 MJ Posted March 9, 2012 Share Posted March 9, 2012 What parts do you need for the closed cooling system? I've got a few of them around for the 4.0L setup. Most people forgo the closed setup and upgrade to the open system... Link to comment Share on other sites More sharing options...
nojaprides Posted March 12, 2012 Share Posted March 12, 2012 I probably have a lot of things you need, I'm in canton. Link to comment Share on other sites More sharing options...
WA_ZJ_Guy Posted March 12, 2012 Share Posted March 12, 2012 i just bought a 89 comanche 4.0 auto 2wd shortbed that i am using for dd/work in need of a few things would like to find a few local sources hp dana 30 stock control arms the rod that connects the rear end to the load sensing valve rear sliding glass both doors will consider newer model xj would like black but any color will do matching door lock set ladder rack for short bed parts for closed cooling set up 4.0 oil pan and valve cover located in statesville will travel for a good deal I have the control arms. not sure how much it would be to ship them, but thinking $10 each. I will ship from Spokane WA 99208. I will be pulling them this week. Link to comment Share on other sites More sharing options...
