Comanchero87 Posted February 5, 2012 Posted February 5, 2012 My o2 sensor and knock sensor were damaged by the exhaust manifold. I need the sensors and a section cut from a engine harness upstream of the sensor connection harness. The damage is before the sensor connections. So I need about 10inches cut before the sensor connections so I can splice the connectors back into the undamaged part of the wiring harness. 87, 4.0, 5spd, 4x4....Thanks
Comanchero87 Posted February 11, 2012 Author Posted February 11, 2012 PM sent. How do we go about setting up the transaction? Thank you
