oldrusty Posted January 15, 2012 Share Posted January 15, 2012 I have a problem with my gas guage that i think i figured out....just looking for other opinions.....First the problem my gas guage only reads two readings. Empty and WAY over full. If the truck has any fuel at all in the tank the needle goes past full all the way to horizontal on the guage. As the tank nears empty i noticed the guage will begin to "bounce off that mark as you start and stop and the fuel in the tank sloshes around. After a few miles of this the guage will go instantly to empty and stay there telling me its time to get gas. I have checked the wiring and don't see any problems. I believe the grounds are ok as the lights and fuel pump all work ok. I'm thinking that the sender is on its way out. What do you guys think? Link to comment Share on other sites More sharing options...
Jeepcomanche87 Posted January 15, 2012 Share Posted January 15, 2012 I'm having the same problem, let me know how that goes if you decide to do that. Thanks Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 15, 2012 Share Posted January 15, 2012 Did you check the connections at the tank? Clean them up? Also the ground behind the left tail lamp? Link to comment Share on other sites More sharing options...
