rocker switches
I used the spot where the stock clock is, otherwise wasted dash space, I have a clock on the radio. Some cutting wiring and plexiglas painted black.
Left side - E-Fan
Right side - driving lights
... the stock holes already have switches for fogs etal. This is in the XJ.
Left side - E-Fan
Might have to do something like this, looks clean :cheers:
Yeah those basically drop in but I got mine from a boating supply much cheaper. here's a link
http://www.boatsupplyonline.com/418-roc ... 99657.html
or google search for condura sealed switch
Thanks for the link. I was looking for a site like that :cheers:
Our NAPA Auto Parts here actually has a good selection of marine switches. Of course we live next to the second biggest lake in CA at Oroville Dam. Lotsa boats.
Theres also this set up I have in the MJ. Found on Ebay. Four switches, each switch has it's own relay. The gang switches came prewired with a common ground. Fits nicely in the "coin holder" behind the shifter (some cutting required).
1. Aux KC driving lights
2. Spotlight
3 Lights and power outlet for inside camper shell and for a cargo light when towing.
4. Reserve, not used
5. and I used the stock switch for the fogs.
