ShadeMJ Posted December 26, 2011 Share Posted December 26, 2011 Hey ComancheClub I have a 1989 shortbed Comanche with a straight 6 2wd with the dana 35 in the rear. Fullsize pic http://i.imgur.com/JnAPf.jpg This will probably be a decently long ongoing project, I'm trying to speed up the pace but we'll see what ends up happening. What I've Done: Taken bed off treated frame with rust neutralizer/convertor Painted the frame black Cleaned up inside of cab Bought a 90 XJ Laredo 4x4 donor bought the steel to make the patches in the floor bought 92 thermostat housing and thermostat + gasket New gas tank What I plan To Do: Swap whole drivetrain excluding rear axle (front 30, tranny, t-case) into the Comanche (Convert to 4x4) Remake brake lines / fix brakes weld in / fab up new floorpans decide and purchase either rough country 4.5" AAL or custom SOA swap in the new thermostat housing with the peacock swap in bucket seats from donor XJ purchase some 33x10.5?12.5x15 tires Audio system/speakers +head unit Run the battery/ground/starter/alternator up with some 0 Gauge custom rungs Custom bumpers Patch/ trim bed and front fenders if necessary + More to be added and finally wheel the dang thing ! I'll add some more picks of the frame after paint later to morrow and some pics of the XJ donor. Should be fun :D Full album (more pictures not posted) http://imgur.com/a/EklHm Link to comment Share on other sites More sharing options...
ShadeMJ Posted December 27, 2011 Author Share Posted December 27, 2011 Finished painted the frame in the back And here's the donor cherokee Someone serious screwed up the paint job :thwak: Link to comment Share on other sites More sharing options...
Donkey Posted December 28, 2011 Share Posted December 28, 2011 you live in florida by any chance looks like a florida xj and one of those crazy gator fans. you see vehicles painted orange and blue more then you should in florida. :nuts: Link to comment Share on other sites More sharing options...
ShadeMJ Posted December 29, 2011 Author Share Posted December 29, 2011 you live in florida by any chance looks like a florida xj and one of those crazy gator fans. you see vehicles painted orange and blue more then you should in florida. :nuts: Yup the guy I bought it from said his friend painted it that color when he was letting him borrow it, but the engine tranny, t-case and axles are in prime shape so it'll make a good donor. Link to comment Share on other sites More sharing options...
ShadeMJ Posted January 21, 2012 Author Share Posted January 21, 2012 Got in the gas tank I ordered today. Also took out the fuel pump from the old one. Surprised the sock was still on there. Over the weekend I'm going to be hooking up the fuel tank along with putting in a new coolant temperature sensor. (bottom of the block) Along with installing the new thermostat housing with the petcock along with a new thermostat and gasket. Most immediate things on the list are fixing the brake lines and welding in the floor panels after we fab them up. Link to comment Share on other sites More sharing options...
ShadeMJ Posted January 26, 2012 Author Share Posted January 26, 2012 Finally put on the thermostat/thermostat housing and petcock. Also took the battery box out broke two bolts so we ground them off and drilled them out. I also quick fixed the coolant system. Using another T-pipe instead of the heater valve, water is always running through the core. Later I'll probably set it up a little nice before we put coolant in, going to put straight water in and check for leaks this weekend. Link to comment Share on other sites More sharing options...
Guanaco.13 Posted January 28, 2012 Share Posted January 28, 2012 wish my jeep was painted :drool: Link to comment Share on other sites More sharing options...
