FKreider Posted December 8, 2011 Share Posted December 8, 2011 Ok guys, first of all I'm new here on the forums. I've checked the site out before since I am a huge MJ fan but I've never owned one untill this past saturday. I picked up a 89 Short Bed MJ with the 4.0 and AW4 transmission. However it is a 2wd truck. I plan on making this into a mildly built daily driver and wheeling truck. So it must be converted to 4x4. :brows: I have owned three cherokee's, a 88, 92 and currently a two door 99. So I have a good amount of knowledge about the XJ platform. I know I need a Dana 30 and front driveshaft, that is the easy part. From what I understand to make this swap as easy as possible I need a AW4 from a 87-90 XJ? Will up to 95 work? I mainly don't want to mess with swapping computers enless someone can help through it. :hmm: Here is the big question I have; this truck has the steering column mounted transmission shifter. This is the first XJ/MJ that I have ever seen with this. Can this be kept with the 4x4 trans swap or will I have to switch to the regular floor mounted shifter? :???: I will post a build thread in the project section of the forums. Link to comment Share on other sites More sharing options...
Geonovast Posted December 8, 2011 Share Posted December 8, 2011 You can keep the column shifter. The 4wd linkages will still mount to the floor, but you won't have any issues with the gear selector. Link to comment Share on other sites More sharing options...
FKreider Posted December 8, 2011 Author Share Posted December 8, 2011 awesome that is a sigh of releif since I really did want to mess with swapping columns. :jump: Link to comment Share on other sites More sharing options...
Geonovast Posted December 8, 2011 Share Posted December 8, 2011 awesome that is a sigh of releif since I really did want to mess with swapping columns. :jump: Compared to swapping transmissions, swapping the column is nothing. Swapping steering columns of XJs/MJs is really pretty easy. Link to comment Share on other sites More sharing options...
FKreider Posted December 8, 2011 Author Share Posted December 8, 2011 Well I've done a couple manual trans swaps and one auto swap in a grand cherokee but I've never messed with the columns. Good to know. :wrench: Link to comment Share on other sites More sharing options...
