2.5 will not start. HELP
My 89 Comanche has a 2.5 and will not start. I was fixing the rear lights last night and it started. I go out today and will not start. :fs1: I do not hear the fuel pump comeing on when I turn the key. Is it the fuel pump or would the ECM fuse be stoping it from starting? Does it have a ECM and if so where is the fuse at in the fuse block or is it somewhere else?
I ask about a ECM fuse because I had a S-10 and would not start. A "chevy nut" said let me look at the ecm fuse and it was bad. Put a new one end and started right up.
Just pored gas in the TB and it fired up. Am I looking at a new fuel pump?
