quentin Posted October 27, 2011 Share Posted October 27, 2011 I have an '89 Comanche, 4cyl,4spd,2wd. Interior lights, dash lights and brake lights don't work. Any suggestions as what might be the problem. Thanks. Link to comment Share on other sites More sharing options...
Pete M Posted October 27, 2011 Share Posted October 27, 2011 checked the fuses? if it's a manual trans, is there any fluid leaking out and running down into the fusebox? Link to comment Share on other sites More sharing options...
quentin Posted October 27, 2011 Author Share Posted October 27, 2011 checked the fuses? if it's a manual trans, is there any fluid leaking out and running down into the fusebox? Thanks.. I think I found it. Radio Wire had a bare spot in the wire that dims the lights ! Now to figure out how much damage it had done.. Probably the headlight switch for one.. Link to comment Share on other sites More sharing options...
quentin Posted October 28, 2011 Author Share Posted October 28, 2011 checked the fuses? if it's a manual trans, is there any fluid leaking out and running down into the fusebox? No fluid leaking out of clutch master cylinder.. thanks Link to comment Share on other sites More sharing options...
quentin Posted October 28, 2011 Author Share Posted October 28, 2011 checked the fuses? if it's a manual trans, is there any fluid leaking out and running down into the fusebox? Thanks.. I think I found it. Radio Wire had a bare spot in the wire that dims the lights ! Now to figure out how much damage it had done.. Probably the headlight switch for one.. fixed the wire, replaced fuse. have dash lights and interior (dome lite) Link to comment Share on other sites More sharing options...
Pete M Posted October 28, 2011 Share Posted October 28, 2011 do you know for sure if the brake lights went out at the same time? Link to comment Share on other sites More sharing options...
quentin Posted October 28, 2011 Author Share Posted October 28, 2011 do you know for sure if the brake lights went out at the same time? No I don't. Just got this Comanche. Do you have an idea about the brake lights ? Wire to switch is dead. Can run a wire direct to switch from fuse block and the work. Link to comment Share on other sites More sharing options...
