bighause Posted September 30, 2011 Posted September 30, 2011 I need help wiring my AC swap from someone who has a truck with dealer installed AC. The dealer installed AC system uses a 4 pin weatherpack connector located in front of the washer fluid tank to tie into the underhood wiring harness. I need pics of the AC wiring harness and connectors used for the relay, low pressure switch and compressor clutch. Once I get the wiring completed, I can sell my donor XJ and use those funds to buy the AC parts I need. Any help would be greatly appreciated!
jimoshel Posted September 30, 2011 Posted September 30, 2011 Image Not Found Image Not Found Image Not Found
