Bacon Posted January 10, 2007 Posted January 10, 2007 my MJ currently has a 3" lift on it, and i'm getting ready to SOA the rear, and plan on putting spacers up front to match the height. yes, i will be taking out the AAl from the rear when i do the SOA. does anybody know what length control arms i'll need for the front when it's all done? stock locations for the rear mounts. wanna keep/restore the caster angle to original specs......thanks
Twisty Posted January 10, 2007 Posted January 10, 2007 controll arm brackets might be the best solution. i don't believe you will ever retain the stock specs with a lifted vehicle, and aftermarket CA's. the controll arm brackets lower the upper, and lower controll arms 4 inches...so a 5 inch lift would be like a 1" lift with stock arms (does that make sence)?
