D44 swap
looking at the drive shaft chart my stock drive shaft is 43.25 inches from the CT to the D35.. the chart also says the D44 uses a 42.25 inch... so just to confirm I need to get a new drive shaft or have my current one shortened, or is there a way i can make due with what i have?
what are some good spring perches? and i plan to keep it spring under axle.. the D44 came from a 91 Cherokee 2wd
Thanks.
