MJ_Trav Posted August 24, 2011 Share Posted August 24, 2011 I was headed to school this mornin and it randomly started spittin and died. Now it'll start but won't run no more than a few seconds. I pulled it home and replaced the fuel filter and pressure regulator, and the fuel pump was replaced a few months back, but it still won't run. Any suggestions? BTW it's the 4.0. Link to comment Share on other sites More sharing options...
tbrand Posted August 24, 2011 Share Posted August 24, 2011 Will it start at all? Or just crank and no start? Edit: Ha, helps if I read the post. When was the last time you had a tune-up? Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 24, 2011 Share Posted August 24, 2011 Have you checked the fuel pressure at the rail port? Link to comment Share on other sites More sharing options...
Geonovast Posted August 24, 2011 Share Posted August 24, 2011 Jump the ballast resistor and see if it'll stay running. It's a very common culprit for a start -> run a few seconds -> die scenario. Link to comment Share on other sites More sharing options...
MJ_Trav Posted August 24, 2011 Author Share Posted August 24, 2011 I did a full tune up about two weeks ago. It's definitely getting fire. I haven't checked the exact fuel pressure with a gauge but i bumped the ignition a few times with the regulator off and it was shootin out pretty good, but I'm no mechanic thats why I'm on here lol oh and what and where exactly is a ballast resistor.... I'm a newbie? Link to comment Share on other sites More sharing options...
Geonovast Posted August 25, 2011 Share Posted August 25, 2011 Ballast Resistor is a piece of porcelain mounted on the inside of the driver's fender. It has two wires running to it, which can easily be jumped together. Power to the pump is run through the resistor after start up. If the resistor is bad(open), then as soon as the startup process is done, it will switch to it, and the pump will quit. If your truck is an early 87, it's possible it won't have one, and therefore that won't be the problem. Link to comment Share on other sites More sharing options...
