SandMountainJeep Posted August 15, 2011 Share Posted August 15, 2011 I know this subject has been addressed before, but what was said must apply to earlier models. I have a 91 MJ with cruise that doesn't work. I can't find the yellow box (module) or the switch on the brake pedal with a vacuum hookup. The 4 amp fuse is also hiding so far. Any ideas? Also where does the horn wire go from the horn? Mine was cut about five inches from the horn and is still plugged in. Thanks! Link to comment Share on other sites More sharing options...
SandMountainJeep Posted August 17, 2011 Author Share Posted August 17, 2011 Anybody? Link to comment Share on other sites More sharing options...
JeffN Posted August 18, 2011 Share Posted August 18, 2011 As for the cruise, alot of times the wire to your brake switch will break, the module for cruise should be right near the steering column under the dash Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 18, 2011 Share Posted August 18, 2011 91s don't have the yellow box or a wire to the brake switch; that's a Renix thing. Read the thread below. Any cruise system from 91-96 will work. I put it in my 91 in about 30 minutes using yard parts from a 96 XJ. Most common point of failure is the column stalk switch, which sounds like your problem. http://www.comancheclub.com/forums/viewtopic.php?f=2&t=12612&p=126489&hilit=cruise+control#p126489 Link to comment Share on other sites More sharing options...
SandMountainJeep Posted August 18, 2011 Author Share Posted August 18, 2011 Thanks for all your help! And ROLL TIDE! Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 18, 2011 Share Posted August 18, 2011 Sand Mountain eh? I know where that is. :thumbsup: Link to comment Share on other sites More sharing options...
SandMountainJeep Posted August 19, 2011 Author Share Posted August 19, 2011 Yep! Are you in my part of the state? :cheers: Link to comment Share on other sites More sharing options...
SandMountainJeep Posted August 25, 2011 Author Share Posted August 25, 2011 Thanks for all the advice. Replaced the stalk and cruise now works. The internals of the steering wheel were in wrong which made the horn sound all the time, so they just cut the wire. Everything now working. Time to do some upgrades! :clapping: Link to comment Share on other sites More sharing options...
