flint54 Posted August 7, 2011 Share Posted August 7, 2011 Sooo, I don't know how to segue from one topic to the next, which is why I've pasted here how the block drain topic morphed into current draw. My plan is to upgrade all the power cables to 1AWG, and the vendor suggests adding a new inline fuse to protect elements downstream of an alternator with greater than OEM capacity, in my case 136A. My observation of the FSM schematics for the PDC and for the charging system show that fuses #8 and #16 perform that function today. They are rated at 60 amps each, for a total limit of 120 amps. Being MAXI fuses, they are available in 10 amp increments up to 100 amps. My Scot genes suggest that I could simply increase those fuses to, say, 70 or 80 amp capacity and achieve the same protection as would be gained by the additional separate inline fuse for a fraction the cost. Don, what have I overlooked? Startup on the 10-blade fans can jump up to 18A. 14A-15A is the norm. They run with a 6A-8A draw. I'm used 12AWG wiring and fuse both my fans at 20A/ea. No problems ever. :cheers: _________________ -Don 91 Comanche LWB, AW4, Hesco 4.6L stroker, 4.09 D44 w. Trac-Loc, 3" lift, Power everything, Explorer disks, CHROME freak. ImageImageImage ROLL TIDE! Image Thanks Don, I was afraid they could pull nearly 20 amps. With two of those kicking on, plus headlights, and whatever else is running, I could be nearing the limit of my poor old OEM alternator. I think they're good for only, what, 65 amps total? Tom _________________ 1992 Comanche Eliminator, SWB, 4wd, 4.0L, AX-15, 2nd owner I think the biggest alternator available on the HOs was the HD 90A; most were 65A-75A. But since you have a 92, the Dodge/ZJ 136A NipponDenso alt below is a cheap and easy bolt-in swap. I did this swap awhile ago and it bolted right in w. no case grinding. Also upgraded my mains cables. It handles both fans, H4 Hella head lamps, A/C on, and full blower no problems. A good upgrade to do on the HOs. _________________ -Don 91 Comanche LWB, AW4, Hesco 4.6L stroker, 4.09 D44 w. Trac-Loc, 3" lift, Power everything, Explorer disks, CHROME freak. ImageImageImage ROLL TIDE! Image Good lead - thanks! I read somewhere that this alternator is externally regulated, via the PCM. Hopefully the amperage increase will pose no risk. Kelley's W.I.P. talks about adding an inline fuse - did you do that also? _________________ 1992 Comanche Eliminator, SWB, 4wd, 4.0L, AX-15, 2nd owner Yes, it's regulated by the ECU based on load demand and battery voltage sensing. Same way the 91-92 MJ HO alts are, and the V8 ZJs and Dodges the 134A alts came from. Yes, I did add the inline ANL fuse (150A if I recall) along w. a set of Kelly's mains cables. _________________ -Don 91 Comanche LWB, AW4, Hesco 4.6L stroker, 4.09 D44 w. Trac-Loc, 3" lift, Power everything, Explorer disks, CHROME freak. ImageImageImage ROLL TIDE! Image Link to comment Share on other sites More sharing options...
jeepdoggydogB Posted August 8, 2011 Share Posted August 8, 2011 I did this... http://www.kelleyswip.com/electric.html Link to comment Share on other sites More sharing options...
