cocy Posted August 5, 2011 Posted August 5, 2011 So I picked up a ax15 from a buddy for scrap price, with the transmission sitting on the floor I try too put it into a gear but it will not go, not into any gear. The shifter seems too be in neural but when I turn the input shaft the out put shaft turns too, this doesn't seem right? I'm no pro with transmissions. Anyideal what would cause this?
jimoshel Posted August 5, 2011 Posted August 5, 2011 Try holding the output shaft while turning the input shaft. If the output doesn't turn then it is in neutral. If it does turn then it's in gear. Remove the shifter. Take a screw driver and see if you can move any of the shift rails. Their are 3 shift rails. In neutral the notch in all 3 will be even, lined up. In gear. 2 of the notches will be aligned and one will be in front of, or behind them. Try to move the one out of alignment until it's even with the other 2. If you can't move it. the tranny is stuck. While it's off, see if you can move the shifter.
