I am in quite the pickle. Went to replace my RE1600 rod end this weekend to discover the misalignment spacers and bushing are seized to the bolt. Tried to order a new hardware kit and was told RE might start shipping August 1. I am taking to Jeep to CO August 6. You can see the problem here.
I figure I will cut my losses and replace the RE trackbar with a JKS unit. But there is a problem. When installing the RE trackbar, I had to drill out the frame end mount to 5/8" while the JKS instructions indicate a required 9/16 to be drill at the frame end mount.
I am on the search for a bushing to fill the extra space so I can install the JKS trackbar. I know little to nothing about bushings or their metal properties that would be good for such an application.
In short, I think I need a 5/8OD to 9/16ID bushing. Help!
Thanks, Brett
Aw crap, sorry I forgot about Motion :fs1: Just curious, what would be your shipped price for the hardware kit and rod end? Would it be possible to have delivery by this Saturday? Feel free to PM me.
I decided to order the Currie Rock Jock TB as it also requires a 5/8" hole at the frame. I will use the RE1600 on the MJ.
Brett
