231 TC
That depends. If you're talking the BA 10/5, yes, they should. The AW-4 was still 21 spline at that point.
If you're talking AX-15, no, it won't as the AX-15 was 23 spline. You can swap the input shafts, if the cases are from the same generation... the pitch on the reduction gears was changed a few times, not sure on when that happened.
The AX-4/5 was 21 spline, but it used a long input on the T-case.
