jimoshel Posted July 16, 2011 Posted July 16, 2011 Want to convert a 2wd to 4wd? Complete axles, hub to hub, 3:55. $100each or $175 for both. Also have a front axle from a 1996ZJ, 3:55 $100
mvusse Posted July 16, 2011 Posted July 16, 2011 Is it possible the 2001 WJ Grand Cherokee axles are actually 2001 XJ Cherokee? IIRC the WJ has a three link coil sprung rear, but that rear looks like am XJ leaf spring setup with the opposing shock mounts. If it's XJ the bolt pattern will match the ZJ front axle. If it's WJ it is lager (5 on 5" instead of 5 on 4.5"). Also on the WJ the drag link goes to the top of a knuckle on the passenger side instead of connecting to the tie rod a foot or so inboard from the knuckle.
jimoshel Posted July 16, 2011 Author Posted July 16, 2011 OOOPS!!! You are correct. That's what I get for going on memory instead of checking. Thank you for bringing it to my attention Jim
jimoshel Posted July 16, 2011 Author Posted July 16, 2011 Yo, Mr Moderator. How do I edit the subject box to show the correction? Using edit didn't do it.
Archived
