M2 CARBINE Posted June 15, 2011 Share Posted June 15, 2011 OK something weird has happend out of no where all my guages quit working, i pulled the cluster out everything was connected and clean. The fuse was good also. Any idea's?? thanks Link to comment Share on other sites More sharing options...
jimoshel Posted June 15, 2011 Share Posted June 15, 2011 What year? Is the voltmeter also affected? Take a voltmeter and check for voltage at the fuse. Both sides. Remove the lighter. Check the ground connection. These questions apply to Renix.('89) HO may be similiar. Link to comment Share on other sites More sharing options...
Garvin Posted June 16, 2011 Share Posted June 16, 2011 The other place to check is the connection through the firewall. '86's don't have many lines that run towards the inside so when the connector starts shaking lose, you might not notice many other issues. Link to comment Share on other sites More sharing options...
