kyleag89 Posted June 6, 2011 Share Posted June 6, 2011 I tried searching but I can't find anything. I am looking for info on bastard packs for the mj. If someone could help me out with a link I'd appreciate it. Link to comment Share on other sites More sharing options...
NewfieMJ Posted June 6, 2011 Share Posted June 6, 2011 http://hellcreeksuspensions.com/ http://rustysoffroad.com/mm5/merchant.m ... _Code=Leaf After buying Rusty's , and seeing HC's , HC's look to be the better choice . No complaints about Rusty's yet though . I pulled 7-900 lb loads last week with mine . It was tougher on the 2.5l than on the springs :yes: . It accually leveled mine out perfect . :thumbsup: Link to comment Share on other sites More sharing options...
kyleag89 Posted June 6, 2011 Author Share Posted June 6, 2011 I'm not looking to spend $100 on an AAL. I want to go to the pick n pull and cut some springs off an S10 or something. Link to comment Share on other sites More sharing options...
88pioneer Posted June 7, 2011 Share Posted June 7, 2011 I found this one to be pretty interesting viewtopic.php?f=2&t=30585 Link to comment Share on other sites More sharing options...
kyleag89 Posted June 7, 2011 Author Share Posted June 7, 2011 An off topic question, I have a C8.25 in my garage ready to bolt in. Can I install that SOA(using the two XJ leaves) and still use the stock SWB driveshaft? Edit: I also like the idea of having better brakes in the rear and a stronger axle with 3.55s instead of the lame 3.07s. I would just have to pull some 3.55s for the D30 and be good to go right? If I go SOA with the 8.25 out of an XJ do I need to relocate the perches? Are they on there at the correct width? Link to comment Share on other sites More sharing options...
Incommando Posted June 7, 2011 Share Posted June 7, 2011 With the price of D30's, at least around here, snag the whole front axle and just swap to get matching 3.55's. Yes, you will need to relocate the spring perches as they differ from the XJ's. Link to comment Share on other sites More sharing options...
